I'm a Ford Festiva owner with an '89 323 engine getting ready to upgrade to a 1992 Protege engine. Looks like a good forum!
New dude
Welcome. I understand that is not the easiest of swaps. You should consider starting a worklog.1990 Protege 4WD
Welcome!!
Let us know if we can be of help---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Welcome to CP. We're not just good, we're the best.
