Just bought a 92 protege 5 speed b6 motor. has slight valve tick and the guy i bought it from said it had adjustable valves and they just need to be adjusted. read up and found out that they are hydraulically adjusted, so do i need a new cam or what can i do to fix that. granted it does have 249900 miles on it has it sits so i expect some mechanic aspects to not be perfect. passed emission but failed gas cap. hell yeah for 500 dollar cars!!
alright... what am i getting in to guys? lol
Welcome.
It should be a B8 or BP, not a B6. The lifter tick is normal. You can try cleaning the lifters, but taking them out and putting them back is a lot of work. I wouldn't worry about it, personally. You don't need a new cam.1990 Protege 4WD
1 3 5
2 4 R
Not sure what's possible NA. 200 whp sounds feasable though. These engines were designed for boost. DOHC swap would be a good starting point. Either the head and cams, or the whole engine, depending on your time/money balance. From there you will have many more aftermarket options.1990 Protege 4WD
1 3 5
2 4 R
Probably bushings.1990 Protege 4WD
1 3 5
2 4 R
