hey y'all, im new to the mazda world. recently purchased a protege lx. anyone got any helpful tips for me? (performance,visual, etc) maybe even some sites y'all recommend to purchase aftermarket parts. thanks.
protege lx
Welcome. What year?1990 Protege 4WD
1 3 5
2 4 R
Sweet. Post some pictures.
Browse the forum. There is a huge amount of information on here about the BGs and how to make them do what you want them to do. You can also search for specific information. If you can't find what you need that way, then go ahead and make a thread to ask your question. See you around.1990 Protege 4WD
1 3 5
2 4 R
Welcome to CP.
As far as engine parts, you should be able to use pretty much anything from the Miata aftermarket.
Most/many chassis and drivetrain parts will be interchangeable with second and third generation Escorts. Oh, and BP powered Sephias. They're good too.
Check out the Junkyard Jems thread while you're at it.1990 Protege 4WD
1 3 5
2 4 R
Originally posted by youngblood93 View Postyepp, I just had to purchase a escort header. hate the cast iron bull**** though. I've got to say, I purchased my protege lx as a daily driver beater for a buck fifty. expecting only that but, this thing blew me away. the 1.8l dohc bp is definitely my new favorite.
