Hi, im Riley and I am new to the clubprotege forum.
New Member
Hi Riley. Welcome to clubprotege.1990 Protege 4WD
1 3 5
2 4 R
Welcome to CP.
welcome...... whatcha bringing to the table for mazda(s)??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
where did you source a PCM swap?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
On the Mazdas247 forum there is a guy who re-flashed Protege pcms with MP3 or MSP software. Costs about 100$ plus shipping they have an advanced timing curve, mo VTCS control (no check engine light or idle issue when performing a VTCS delete. And becuase the MP3 was a LEV (low emmisions vehicle, father than a standard Protege which is a (ULEV) ultra low emissions vehicle. It also won set a check engine light with a header.
Sent from my XT1032 using Tapatalk
