Thanks for the add. I was referred by an escort Facebook group to answer my bg questions. So much info!!! Ive owned a 00 zx2 s/r for the last 19 years. It sat for about 5-6 years and I’ve been bringing it back to life for the last year. Mods are 20% tint , svt focus intake manifold with 30 lbs injectors, tb, maf, janky intake tube, jba shorties, 98 zetec valve cover, dyed mx3 seats, udp, larger rear sway bar. Soon to happen Svt focus header with 2.5” exhaust, tuner, and the bj 2 pot brake swap from the write up. I picked up some p5 spindles last pick n pull sale. Some type of coil overs. Also my s/r never got the polybushing luckily the kit I bought years ago where still in the trunk!
Zx2 owner
Welcome!
Is the geometry on the zx2 spindles close enough to match p5 stuff properly??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Welcome.1990 Protege 4WD
1 3 5
2 4 R
Welcome to CP.
