I am aware of that, but were there improvements to the oil passages to the newer KL03 cranks, or are they straight up, unchanged since the beginning?
DeeAOne's BF KLDE Swap.
i think its ****ty to seal up the oil squirters. mazda sure made a fail with the KL oiling---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Comparing a reg KL crank side by side to a KLG4 crank, i dont see any external differences in the oiling set up. But thats doesnt mean something might be internally different.
Mazda didnt seal any oil squirters. They just didnt do any of the machining for them to begin with on the newer motors. They realized they just werent needed. Even though thats just extra security in my eyes. You cant have too much lubrication.
Im using a KLG4 crank, and pistons on my current KL build. going for an all OEM Mazda engine using the best parts used between all the versions. I would have preferred some ZE pistons, But the G4 one's are close enough compression, and were free.~PaTricK~
-Current car's-
What are you driving?
Went to Summit Racing over the weekend to pick up a goodie for the 323. Always wanted one, and for the price I couldn't pass it up. Apparently, Kouki and Zenki approve of it as well. lol
'88 323 sedan, K-swapped..
nice seat man!!-Jack
going to put 2 seats in??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Ryan, eventually. Don't have all that cheese like you. lol, and thanks bogaut.
Well the build is still crawling along. Life getting in the way as usual.
DON'T SAY ANYTHING ABOUT MY DIRTY INTERIOR! lolol
Spare block is torn down. Cylinder walls are in pretty good shape for sitting for so long. Should work just fine.
I finally got around to making some brackets up to put my seat in using my stock rails. I took some steel plating and drilled holes to widen the seat track on one side. Nothing fancy, just want it to work.
Looks factory where visible.
Still sitting.
seat looks HUGE compared to the passengers one! Hows it for comfort?-Jack
Ryan, eventually. Don't have all that cheese like you.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by Mazda_Powered View Postseat looks HUGE compared to the passengers one! Hows it for comfort?
Originally posted by FE3-323 View Postwhats with the wisconsin jokes
Originally posted by Mr N4SA View PostHurry Up buddy.....lol!
I miss my fav BF.
What happen to the steering column surrounding covers?
Originally posted by DeeAOne View PostIts a little stiff but I'm hoping it softens up once I sit in it. It still fits pretty well even though its bigger. I can reach all adjustable handles fine.
lol didn't even think of that!
I have them. Took them off to look at my combo switch. Ive had no blinkers or wipers for over a year. Ready to fix them. Lol
Alright guys so don't shun me from the forums BUT, I think the build plans are changing again. I want to go back to my original plan of a beast N/A motor.
So far I'm looking at:
K1 Rods
Wiseco 11 or 12:1 pistons
Colt N/A's 218/218 (or is it 210 exh?)
98+ solid lifters
Interprep springs
May or may not use my shaved ZE heads. I'm worried that shaved heads with those pistons will either require a REALLY good tune, or just not be possible at all.
Everything else will probably just be new OEM. Oil pump, water pump, etc.
Anything vital I'm missing?Last edited by DeeAOne; 04-15-2013, 10:52 PM.
make her rip!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
