DeeAOne's BF KLDE Swap.
    i literally only had to splice into 4 wires to get my car to run and i didn't use the KL fuse box, its added wires that aren't necessary and will clutter up the engine bay
    the only thing the my harness needed was on/start power for,
    dist
    sensors (just one wire that splits to every sensor through out the harness)
    injectors
    and constant power to the ecu
    anything more then that is un-needed since you can get little fuse holders that are much easier to tuck away then the big KL fuse box, plus the KL fuse box has fuses/relay for sh!t that won't be used in your 323
    1988 323 GT - B6T Powered
      I'm with Damkid on this one.... you only need the power he says. I used the relay for the EGI and I added one for the fuel pump ( which you already have ). Just take your time and put a post up when you get stuck and one of us will help you .
        alright..im really trying lol. this is the first time ive ever done any wiring so excuse me for not understanding the simple things.
        what is that one wire that splits to every sensor? color?
        this was the reason i thought i needed this fuse box. this plug looks to be one of the main ones from the fuse box to the harness.
        for reference, there it is next to the CEL box.
        so what should i do, run the b6 fuse box and use the stock alt power wires?
        or, the klde alt power wires with the b6 box. the wire im holding is what would bolt onto the b6 fuse box.
        '88 323 sedan, K-swapped..
          What harness are you using? MX-3? 626? Probe GT?
            he has a 626/probe box. all you need to do man is run your fuse box, starting wires, alternator wires and sensor wires for cluster sensors.
            I am at the point where I have to hook up the power at all times wire that ran to the under hood box, I'll post up after dinner when I get a pic of the wire and what color you will need. after that mine should fire! I can't wait.
            1990 Protege 4WD 5 Speed
              that was an mx6 box. i have a mx3 gs box too. and its a 626 harness.
                do you have wiring diagrams for the harness you have? it maybe easier to help you with the wiring if i gave you a call?
                  ITS ALIVE!!!!
                  fires up but dies shortly after so im hoping its just the maf not reading right. sounds very strong though from the 2 or more seconds its runs.
                    Congrats!!!! i should be done making your bracket in a day or two
                      Sweet. Hopefully I will be able to make a similar post later today
                      -Steve
                      94' Protege < Worklog<SOLD!
                      VF10 powered!
                      262 Whp & 257 Wtq
                      13.1@107
                      '02 Suzuki Bandit 600s
                        yay
                          thanks bro. just let me know.
                          so the way it sits right now, the main wires are all just ran straight to the battery side of the fuse box. i would have to wire those main wires to a switch. fuel pump, dizzy, etc. but i want to see if i can get them to work through the ECU and a relay. but at least it fired.
                          what would you do clubprotege? keep it how it is and run a main switch inside the car, or wire in a relay?
                            I would wire in a relay to the ignition wire.
                            -Steve
                            VF10 powered!
                            262 Whp & 257 Wtq
                            13.1@107
                              Glad to hear you got it running!!!
                                Sick!! Congrats man!! Your one of few with a KL swapped BF. Now tell me it wasn't worth it.. haha.
