DeeAOne's BF KLDE Swap.
Nope I used a bg gear. I think they are the same as a bf anyway. They are taller than what's supposed to be in there but they still slide in and work. You just cant bolt it down in the transmission with that little 10mm bolt.Last edited by DeeAOne; 02-07-2011, 08:05 AM.
'88 323 sedan, K-swapped..
awesome man! sounds like a winner
you should do some porting work!!!! do it!!!!-Jack
Originally posted by Rusty323 View Postdo the milli heads have solid lifters like the g4?"Discontent is the first necessity of progress."
plans sound solid man, just be careful when getting the heads machined since it is a V6 engine and removing material from the head will alter the cam timing...there's info about this on mx6.com i believe.-Jack
Originally posted by bomdoutscort View PostNice. I give it to you...you've got some skills and your on your way to an even faster car then you had before. Keep up the hard work.
Originally posted by Mazda_Powered View Postplans sound solid man, just be careful when getting the heads machined since it is a V6 engine and removing material from the head will alter the cam timing...there's info about this on mx6.com i believe.
Originally posted by Rusty323 View Postsince ur reving to the sky....y dont u get some g4 lifters?
id have to get G4 heads and port them to ZE specs to do that"Discontent is the first necessity of progress."
so ive been researching for the past few hours, and i really feel like i want to start gathering parts to boost after this rebuild. ive already decided im going to megasquirt the ZE after its back in the car.
what do you guys think? i like the all motor feel, but who doesnt like a nicely tuned boosted setup?
That would make it the best kl swapped bh around1993 Protege LX-Midnight's shadow SOLD
