Originally posted by Damkid
View Post
My KLZE Ford Festiva build thread
Well i did get around to test fitting the headers tonight, the front one fits great
The rear..... not so much
Although theres plenty of room for the intermediate shaft which is great
As you can see it hits the steering rack and the flang isn't flat against the head yet, so just like everything else i will modify it to make it work :lol:
But i'm loving seeing 2 manifolds coming out of my tiny engine bay lol
1988 323 GT - B6T Powered
Originally posted by nerd racing View PostI want to hear some open header vids so don't button up that exhaust just yet! :D
Just read this whole thread. I was going to do this swap with my k8 from my mx3, but unfortunately I had to sell the stiva to fund my mx3 build(it now is an elecrtic car in chicago, lol!). Im so glad someone else had the nads to even concieve this (much less build it) other than me. I still hav my k8 and i just may have to hang onto it till I get another festiva. It won't be as sweet as a ze, but it'll look just as menacing, lol! Awesome job, can't wait for completion.
the rear isn't off by too much tho!!! that's awesome.
oh i saw at canadian tire the female end to the exhaust flanges, so you can make your exhaust setup
here's a pic of what i mean lol http://image.carcraft.com/f/9219702+...all_flange.jpg-Jack
Are those pacesetter headers?1993 Protege LX-Midnight's shadow SOLD
Originally posted by Turpro View PostAre those pacesetter headers?
Originally posted by Mazda_Powered View Postthe rear isn't off by too much tho!!! that's awesome.
Originally posted by 93LXDOHC View PostJust read this whole thread. I was going to do this swap with my k8 from my mx3, but unfortunately I had to sell the stiva to fund my mx3 build(it now is an elecrtic car in chicago, lol!). Im so glad someone else had the nads to even concieve this (much less build it) other than me. I still hav my k8 and i just may have to hang onto it till I get another festiva. It won't be as sweet as a ze, but it'll look just as menacing, lol! Awesome job, can't wait for completion.
Well here's how i modified the header to clear the steering rack, i cut the pipe bent it til i closed the gap and welded it back together
And when installed, theres now tons of clearance for the steering rack
But i went too far and now it doesn't clear my axle
So tomorrow i'll be moving it back towards the rack so it'll workLast edited by Damkid; 02-10-2010, 06:56 PM.
I had the header at work so i couldn't check the clearances but i should get it right tomorrow (hopefully)
almost made em fit lol-Jack
Got it right this time fits perfect now!!
I also brought some other parts into work that needed a bit of work, since i had to cut around the rad support for clearance for the alt. etc. i lost the bolt holes for the trim piece below the headlight and 2 out of 4 mounting holes for the headlight itself
In this pic you can see how i moved the bracket over and re-welded it, and that metal is extremely thin so it burned through very easily
And a self-tapping screw to bolt it in place
For the headlight i welded a little tab on it to make a good point to bolt it to the body and it works pretty good
And everything looks factory again once all the pieces are put back on
Once i got those little detail things taken care of, i pulled the engine back out so i can change out the broken water outlet on the engine
And what a PITA it is to get to, i have to take all the timing belt pulleys off in order to get to the bolts
and the new part ready to go on
i got the new one installed and got most of the pulley's back on but i had to stop so i could pick up my girlfriend from work (she'd be pissed if i was late lol), so i'll finish it up tomorrow
HTS-2000 Use this if you ever need to fix aluminum again. Saves ****loads of time for me. I use this stuff alot and it has always worked fine, just as long as its not a very high temp area. 99 percent of the time your not gonna put in a place thats to hot.ah, it's wonderful driving a car that goes slow.. makes it easier to aim for the old people crossing the street
