no, it's the BG drivetrain! and yes the engine is a little bit tilted foward but you don't really see it in the pictures....
rallycross GTX
More pics of the bg drivetrain? did you keep the BF knuckles and hubs or swap in the BG?Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
1990 x2 BG AWD Protege
1991 Escort GT- SOLD
2005 Corolla
I'll get some pics of it tonight! But it take custom motor mount ( right and left) the front one just need to redrill the cross member like 1 inch beside the stock holes...
You need the BG axle and halfshaft, but you need to put the outside cv joint of the BF... The driveshaft bolt right up if you fit the engine correctly!!
I'll send a little video soon... The engine runs very well on MS3 full sequential!!
Greg
awesome glad to hear you got it running. Looks like a clean install-Jack
What size tubing & wall thickness did you use? any plans for additional taco gussets @ the joints?
Im fond on you roof cross.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
gussets only need to be used where you need to transfer load, otherwise they can actually weaken the cage by transferring the load onto a single leg of the tube and cause it to fail.
in otherwords, a good cage needs minimal gussets."Discontent is the first necessity of progress."
im sure jim would have something to say towards that^^---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postim sure jim would have something to say towards that^^
let jim speak his own words"Discontent is the first necessity of progress."
