I like that spot.. remove the head light for track days and have some fun.. might want to move it back a little bit for wiring/light servicing if you plan to drive it with the head light installed..
B6T festy build thread
Still working on the final postion so well see where it ends up.
13hrs and 440mi later I have all the transmissions I need to build the one I want.
12 cbr250r: daily ride
01 saab 9-3: daily
98 gsxr 1100: for sale
93L: money pit/ space waster
92GL: low and slow beater
90?: the rust free shell
89LX: swapping to rust free shell
89L: for sale
89L: parts
87 conquest: dohc 4g64 swap underway
76+80 vw dashers: for sale
Tell us about your tranny fantasy (lol) what are you going to end up for a final, and such?
Turbo placement looks kick ass though lol love that! When I go to build a manifold myself, I'll be placing the turbo near that position as well. I'm just planning to have the turbo sit horizontally left to right, vs your vertical front to back setup. I figure this way I could run the downpipe in front of the engine and under still.-Jack
Lol kia case with plate mod, 97 escort gears, and 26 spline mfactory diff.
I thought about mounting it like that but I'm running out of room out front. The exhaust is going to have to squeeze in between the starter and the rack. I had a piece of 3.5" pipe laying around and it would just barely squeeze back there so I think I can make it work with 3". If I can't I'll just break out the sawzall and dump it out the hood lol.
Sent from my C771 using Tapatalk 212 cbr250r: daily ride
01 saab 9-3: daily
89L: for sale
89L: parts
Bunch of goodies have been showing up lately.
Test fitting the new radiator
And found out that hydro trans have different mounting points than cable.
The back mount will bolt up to the trans but aparently the case dimensions are different and now it wont clear the rack.12 cbr250r: daily ride
01 saab 9-3: daily
89L: for sale
89L: parts
minor set back?-Jack
Should just have to redo the brackets that go from the trans to the crossmember.
01 saab 9-3: daily
89L: for sale
89L: parts
I am converting to a hydro setup. The problem is that the hydro case front mounting points are about a inch higher than the mounts on a cable case.
01 saab 9-3: daily
89L: for sale
89L: parts
I'll use the kia trans I said.... it'll be easy I said
So last night I swapped my mfactory diff into the kia case so I could put my axles in and position everything to start on the new brackets. Once I tried to put the halfshaft in it became very clear why nothing is lining up. For some reason they rotated the back of the trans down an inch compared to the older cable trans. So now the halfshaft hits part of the oil pan right by where it goes into the diff. Also it won't bolt to the block anymore. The holes are an inch off and its closer to the block so when the bottom of the bracket is touching the block the top is angled out a good 1/4-1/2". The only up side to all this is that if you put the axles in the same spot as before the motor now sits about 1/2" further back and 1" higher.
01 saab 9-3: daily
89L: for sale
89L: parts
Geez, I wouldn't have thought the cable trans case would be that different! I know you'll get it sorted out, but still sucks none the less.-Jack
time to build yourself a new bearing carriage for that halfshaft. its just a press in situation. no retaining clips/etc so it shouldn't be hard at all.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Hmmm ill mess with it once I get the mounts done.
Didnt have any metal to start on the mounts so I did this instead.
01 saab 9-3: daily
89L: for sale
89L: parts
Is someone building a custom intake?-Jack
