Phew, motor is finally out. Really wasn't any more difficult than a miata engine pull, perhaps even easier. Having more space in my garage would have made this much easier. The whole drivetrain could easily slip out under the left side frame rail.
Illustrating the tiny space i'm working with. My bench was only 2 feet behind that hoist. Just barely enough space to maneuver it.
Engine on the ground in the engine bay while I decided how I was going to get it out.
You can kind of see how it would have slipped under the frame rail easily if I had the space and a skateboard.
Decided it just needed to come out the top.
Tiny little turbo and cracked manifold.
I really want to put this oil feed hardline on my miata. I'm going to either make one or find one from a B6T.
And the engine/trans on the floor. It took a million turns of the hoist to get the motor turned 90 degrees from the way it was sitting in the engine bay.
Lots of cleanup to do. Need to get my hands on a pressure washer.
Overall it wasn't a bad job. Again, its really weird working on the same motor thats in my miata in this configuration. The starter and alternator are remarkably difficult to get to when the motor is in the car.
