I used to know the answer to this, but is the GTR rear diff a viscous unit or clutch-type? Memory seems to recall it being a VLSD, but I think that it wasn't usable with the BF pumpkin? I forget / don't care enough.
Jeff's 323 GTX
Bf and bg use the same rear diff casing. The GTR diff is a Viscious LSD and can be put in a bf case. Im using a stock miata Torson LSD in the back of my protege 4wd and know those will swap too"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
Originally posted by trailrider098 View Postadded some a few mods, s10 front dam, rocketman chip, some Recaro seats and a GTR rear diff., Tenzo-R DC6 16'' wheels
Originally posted by trailrider098 View PostFiberglass rear hatch (not yet installed)
Triangle skirts (will replace USDM when the car is painted)
GTAe hood hump
Originally posted by sprint45 View PostNice build so far. Where did you find the GTR replica front bumper? I noticed you had the GTAe front bumper as well. Which one are you going to use? I would definitely be interested if you ever wanted to sell it.
Scott, Im using a complete GTR rear diff and housing/case. the case is the same as a BF chassis GTX, just a lsd diff. The rear hatch was from a group buy about 7 years ago. Aperently only one person in the US bought 2 of them and he finally sold me the extra one. The triangle skirts will be added when i do all my body work since they attach to the car via plastic clips which require holes on the rear quarter panels. GTAe hood hump was pre-facelift gtx stuff and i love it
Now if Terry could just sell me that rear plate support piece he has layin around so i can complete my master plan/the back of my car........"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by trailrider098 View PostScott, Im using a complete GTR rear diff and housing/case. the case is the same as a BF chassis GTX, just a lsd diff.
Thanks for the other answers, too.
hold up a sec...
Originally posted by trailrider098 View PostIm using a stock miata Torson LSD in the back of my protege 4wd and know those will swap too
Edit: This just popped up from Bob Bundy on the Yahoo!groups GTX list:
"Torsens wont fit they are larger 1.8l miata size unless you get serious with some custom mounting of a different carrier assembly. 1.6l miata VLSD or a mazda comp clutch type bolt into the GTX housing. Need to re-use the ring and pinion from the GTX to keep the 3.909 ratio."
Yeah... I think a lil' bit more explanation would be a good thing, Jeff.
Anyway, this brings to mind my internal debate about viscous LSDs vs Torsen/helical gear-type vs. clutch-type. Each has benefits and compromises: In the rear, a clutch-type is superior for rally competition. However, it's a bit jerky in operation (and they require maintenance over time). The Torsen variant is super-smooth but only works when both tires have *at least some* grip. This makes it fairly inconsistent on loose surfaces and occasionally completely useless (still WAY better than open, though). Finally, viscous is as smooth as Torsen and consistently delivers torque to the proper wheel. However, it is also reactive by nature requiring slip to exist before it can step in and correct anything. Folks consider them "weak" in effect as a result.
FWIW, If I had my "druthers" I'd have a Torsen up front, moderately stiff viscous in the middle, and clutch-type out back. That's with a 10 -15% gear torque bias to the rear, of course. I'm eyeballing the BG AWD system and also the DSM setup (along with 4G63).
Cheers,
P.S. Sorry if this fixation of mine on diffs = a thread hijack! It seems to be related enough to your build to keep it goin' but state any difference of opinion if you have it, please!Last edited by Scott@USRT; 01-05-2011, 09:28 AM. Reason: -found additional evidence to support my point
I'm posting from my phone now but Ill edit this tonight, I have pics on the computer from the rear diff install on the protege diff. I was pretty sure it was a torson diff but i did buy it from a local miata guy so maybe it was just the miata viscious diff.
And yes, the Mazda Gtr rear LSD is the same as a miata viscous LSD. You are also correct, the 7inch gear from a BP miata will not fit into a 6inch Gtx/gtr/b6 miata rear differential case. I always thought there was a factory option for torson or viscous rear LSD's on the miata."See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by trailrider098 View PostI always thought there was a factory option for torson or viscous rear LSD's on the miata.
P.S. Thanks for the great links, BFMRGTX.
So i bought the rear lsd from a 1.6L miata, owner claimed it to be the torson lsd. i took the diff out of the miata case, open diff out of the protege case, swaped ring gears and reasembled(basicly). what i meant in my last post was that i thought torson and viscious lsd's were availabe for the 1.6, i know differentials for the 1.8 were an inch to big for our case
left pic is the lsd i installed in my protege, help please if anyone can tell if its torson or viscious
on the right is the slightly bigger 1.6L miata ring gear vs. our gtx/gtr/pro 4wd gear
Last edited by trailrider098; 01-06-2011, 10:29 PM."See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by NoBoDy_nz View PostNice Build, where did you get the CF bonnet from?? i want one so bad to finish the look of my car off, are you still able to get them ?
