hahaha i knew you would , you after the lower mounting points from my gtx ones?
1985 Mazda BF 323
why are you downgrading??? i dont understand.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Why don't you FE3 swap everything?-Jack
Well the reason is I'm going to be a dad soon, I have about a 6month range to build a motor that is turbo. The fe3 is going to cost me too much to turbo, even with just evo running gear is will still cost me well over a grand and that's without rebuilding it. Plus the bp is quite high revving. I'm not getting rid of my fe I would never do that maybe in a year or so I will rebuild it and turbo it once everything settles down a bitFE3 POWA1985 Mazda 323 BF5P - FE3 powered
the BP revs like **** compared to a FE3. the rod ratio is ****!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
