hello folks, i am starting my swap from my capri that i have owned for almost 5 years now, i finally found a good 323 car and i actually drive it on a daily basis, so first i am going to post some pics of the diff out of my g series trans that i am experimenting with, "the 6 gear diff" i think kia has these stock on some models but i made my own lol so here it is more pics will come and if anybody has any input on this swap to help me feel free
turbospoolins capri to 323 b6t swap
Good luck with the build. So you're trying to make it a 6spd?1993 Protege LX-Midnight's shadow SOLD
no not 6spd a 6 gear diff for more strength not 6 gears as in 6 spd lol look at the pics top is a normal diff and the bottom is with the added 2 extra spider gears(one on each side) i have blown 5 diffs in the capri because i was running to much boost they would last about a month or so the boom!! lol roll back time! lol the pics are not the completed diff,i put plates on the shafts that are sticking out on each side of the diff to hold the shafts more steady but they are also welded to the other shaft on the inside,once you do this its permanent,no taking it apart lol i just got tired of blowing diffs and this i hope will be a permanent fix, so if it blows again thsi diff will be trashed and start over againLast edited by turbospoolin; 03-31-2011, 01:31 PM.schmlick blang
The diffs blow from too many one-wheel wonders. Burnouts are hell on them. The diff holds up fine to high boost.1991 Capri XR2 "GTXR2" BPT AWD Bastardization/conversion
Creator of the B6T Rocketchip
www.werbatfik.com
Early 5spd Ford Escapes with the 2.0 Zetec had the 4 spider differentials, or 6 gear as u call it.
yep you are exactly right the spider shaft get over heated by the one small gear spinning on it and then galds to it then causing the entire shaft to rotate snapping the roll pin and then ultimately shooting the shaft through the trans case yep crap situation lol but dam i loved burn outs but i never really tried to on purpose the dang thing would spin at the touch of the throttle, but i had fun anyway lol 24psi didnt help it any tho lolLast edited by turbospoolin; 03-31-2011, 06:29 PM.schmlick blang
more pics the 323 and the capri
Some pics of what i am working with the black plug is what im concerned with it will plug into the 323 but the wire locations are different and the capri side has more wires. even tho dirty the capri engine runs very well no smoke no tics or pecks has 112,000 miles,thinking about using the tdo5h turbo,the stock one is in perfect condition,nothing wrong with it.do need some help with the harnesses 91 capri to 86 323,both fuel injectedschmlick blang
UPDATE!!! hey guys the turbo 323 lives!!!!!!!!!!!!! i have finally got the swap almost done!!! i did decide to go with the stock turbo seeing that it did work fantasticlly and with the 323 being a wwaayy lighter car, i shouldnt need to turn the boost up as high as i did when the engine was in the heavier capri. but yes the actual install was super easy didnt take but about 20 mins lol, here are some pics as of now,[IMG][/IMG]
schmlick blang
please tell me you have more completed pictures of the diff......---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postplease tell me you have more completed pictures of the diff......schmlick blang
