My 89' 323 GT Worklog
    ^^the diff swap will work the exact same as it did with my festiva, I'm dead positive in that one
    1988 323 GT - B6T Powered
      Edit: wrong thread
        Progress!! As you see the B6T is out and front end off, tomorrow night I'm hauling it to my work to repair the rotted out lower rad support
          Ready for transport to my work for some patch work on the lower rad support
            I like the kids approval lol
              Old rad support cut out
              Boxed in the frame side
              New support welded in
              And the old rotted section
                Nice work. It's weird how rusty that old one was, and how clean the rest of it is.
                1992 Familia GT-X
                1988 323 GTX
                2011 F150 Lariat Ecoboost
                2014 Civic Touring
                  Ya I totally agree, all I really need to do still is drill holes and weld in some sleeves for the bolt holes so I can run bolts straight through it..... I wanna weld in sleeves so that over time the bolts don't crush down the new section..... Same for the sway bar mounts and weld tabs on for the lower hood latch bracket, rad mounts etc
                    Yeah, I forgot that's where the sway bar mounts. That explains the rust. The car has been driven hard, and long.
                    1992 Familia GT-X
                    1988 323 GTX
                    2014 Civic Touring
                      I been absent from the forums for a while, but I have some good progress to post once I get the chance to post pics
                        So after I got a new piece welded in for the lower rad support, I wanted to test fit the engine to see what room I had to work with for rad clearance
                        So then I grabbed the VW rad I had kickin around and it fit nicely, so I made up some mounting points
                        Then the engine bay got a coat of black paint
                        Knowing the issues I had with clutch cable adapters on my festiva I decided to convert the GT to hydro clutch, so I got my hands on a GTX clutch pedal and master cylinder
                        Here's a comparison pic of the GT vs GTX pedal, GTX is the top one
                        And all parts bolted up almost like stock, the master took a slight but of modifying and the pushrod needed to be shortened
                        I had to put the tranny in for any fab work needed to get the shift linkage bolted up
                        Then I put the face back on it
                        Before I could put the engine back in, i needed to make up the int shaft mounting plate (remember I swapped in a 26 spline diff so I can re-use the stock axles)
                        Then the engine went back in
                        Lots of header clearance
                        That's how far I got until I got distracted with buying this AWD protege (drive shaft was pulled prior to towing) build thread to come shortly
                          nice using the factory rear and side engine mount?
                          etude ftw!
                            Stock rear GT mount, stock front KL bracket but i had to re-drill the crossmember to match the KL front mount.... i still need to make the passenger side mount
                              holy updates batman!!!! im a little confused. so now you have 2 KL festiva's??? and a KL 323gt?
                                Lol no, I have 2 festiva's, one is stock though and just got replaced with an AWD protege (build thread coming up within a few mins)
                                THIS 323 GT WILL BE FOR SALE WHEN FINISHED
                                Price is still to be determined, but discount price will be given to forum members lol
