I have a mazda protege 2003 and im going to change the timing belt is their anything else i should change? I want to change all belt which ones should i change?
changing timing belt. HELP..
cant help you here, you gotta post in the BJ chassis forum"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by neuspeedescortthe proper spelling would be "Launchabilitiness" i do believe.
-88' Mazda 323 GTX, caged and ready for dirt
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
-87' Toyota Land Cruiser, 33's with slight lift, safari style!
Good luck those are fun. Y not use a good OEM or gates racing (300% stronger) belt, replace the water pump, get a haynes book if this is your first timing belt. Check and double check all your non existant timing marks. Interference motor i think... special required to hold cams, or use a flat stock peice of steel on right side of head (lock the cams).
