i have a sohc b6. the issue is that sometimes i get spark and sometimes i dont. i know its not the coil because i replaced it and it did the same thing...so its before the coil, whatever the problem is. i will start it and sometimes it will run for half an hour or sometimes only 5 seconds. and then it wont start again until i unplug the coil or wiggle the wires. i have replaced the clip too so i know its not that. if anyone knows please help. thanks!
Help me please.
how old are your plug wires? and have u replaced the disty cap and springs?"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by neuspeedescortthe proper spelling would be "Launchabilitiness" i do believe.
-88' Mazda 323 GTX, caged and ready for dirt
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
-87' Toyota Land Cruiser, 33's with slight lift, safari style!
well see, i figured it wouldnt have anything to do with the distributor or anything inside of it because sometimes there isnt even power at the ignition coil coming from the engine harness. and the coil is what gives the dizzy power....right? lol
and the wires are brand new.
'88 323 sedan, K-swapped..
'03.5 Mazdaspeed Protege - miss it so much..
'01 Dodge Ram 3500 Cummins - 323 hauler
checked the grounds, didnt find any that werent connected or had a bad connection. and im pretty sure the ECU is fine...heres my question. can something in my dizzy cause my coil not to work and my car not get spark? sorry if it sounds like a noob question. lol
On your disty there isn't anything that would mess with the coil cause it's not electronicly advanced it's mechanical.
I recently did a bunch of engine work on my 88 Gtx and my biggest worry was cracking wires in the harness. I noticed while doing some wiring that the original wires were dryrotted and just moving some caused cracking. Hopfully your car dosent have the same problem since you say the problem goes away after wiggling the wires"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by DeeAOne View Postjust thought about this. what about the ignition module??
Pullin the harness isnt too hard man in the bf.. a few hours, 10min to get it out, and the other time getting it back in....lol
Originally posted by jitb37 View Postthats a thought, there are plenty in the yard.. the one on the Bf looks exactly like the ones on the Protege/escort etc.. ive got one from mine that worked.. if you want to test it and make sure.
