First, thanks for you r help on the stick conversion however I have found a 93 Capri non-turbo w/auto trans that I bought and will be swapping everything over since this will uncomplicate life v. converting an auto to a 5spd.
My question is this, will the SOHC engine harness mate up with the DOHC engine or do I need to swap outthe harness as well? I know I need to swap the ECU. Also do I need to take the fuel pump from the Capri?
I plan on taking the rear disks, front hubs harness, drivetrain and ecu. Anything else that I should move over to the 323 or that is worth putting up on ebay?
Thanks!
Thanks!
