ok not sure if in the right place to post this but i was wanting to know if the bp clutch and fly wheel willl work with 88 323 f series tranny? like if the starter will line up to the flywheel. or could i use the bp starter?
clutch and flywheel question
starter and flywheel should fit fine, but the clutch disc will not fit the F series transmissionEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
not exactly, the f series clutch wont fit the g series flywheel
whats wrong with your current flywheel?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
the BP starter is fine, all the B series flywheels have the same ring gear
but yes you will want the flywheel and clutch to match the trans, unless you can find an 8 7/8" disc with the f-series splines... then you could run that with a BP flywheel and pressure plate and have a much more durable clutch.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
