Been a while and I'm finally able to wrench on my GTX a bit. Installed a Rocketman ECU, and I'm trying to get the boost up.
I made a home brew boost controller, I used the following link.
http://www.dsmtuners.com/forums/arti...ler-works.html
I then installed it in line between the wastegate and the pressure side of the intake.
It made some difference. I'm getting about 10-11psi, when before I was reaching 8-9psi. I did disconnect the boost cut off.
I have tried stretching the spring, tightening the screw down all the way, and I still can't get over 11(according to my gauge). Do I have something wrong here?
Thanks in advance.
Thanks in advance.
