I know it doesnt have the fittings for the turbo stuff, but i have a perfectly good B6 SOHC siting here and a BF friend who needs a bottom end.
is the BG's B6 the same block as the BF's B6T?
New Daily stock 1.6L 1999 Mazda Protege LXTags: None
yep, rusty is building up a spare block so we are contemplating using my old B6 bottom end since its here and confirmed functional"Discontent is the first necessity of progress."
compare oil/water ports in the 2 headgaskets?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
if mazdas as cheap as everyone else its possiby the same gasket, the headgasket i ordered for mine came in as a bp26-10-271 not that it means anything...lol.....92 protege lx-
94 protege lx-
95 escort gt-ms2e/ms2extra pre3.3alpha5 gslender v2.8-e85-vj23@12lbs----dead--
are you a thinker, or a believer?
i was worried about deck height mainly. but ill see if i can scare up some used HG to check"Discontent is the first necessity of progress."
deck height should be the same, i am pretty sure the rod length and stroke is identical for every b-series engine...?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
yep im with jon....i did a lil reading and all the b6 doch and sohc have the same bore and stroke. i got my hands on a b6t block, but ill be using gtx rods (thanxk yunv) with b6 sohc 9.2:1 pistons and crank with all new bearings, oil pump and other stuff. i wont be doing a build thread. cant bother with working and taking pix step by step. If i get it up and running ill post pix and let u guys know. prob even dyno #s when in tuned with ms.....and shawn gonna help...i hope
Originally posted by therieldeal View Postdeck height should be the same, i am pretty sure the rod length and stroke is identical for every b-series engine...?I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important.
._________________________
