your biggest obsticle would be the gearbox. anything is possible with time and money
if its a bg chassis then you can put the internals into a v6 transmission case and bolt up the awd ( theoretically) you would have to have both transmissions side by side to look
i would like to see that. that would be pretty cool
V6 with an MPV gear box.. good luck making it all fit though.
1988 White GTX - #1 parts
1988 Black GTX - #2 reliably broken touge monstar (294,000 miles no rebuilds) - dead 1988 Blue GTX - #3 in progress (view here)
1988 White GTX - #5 Rally car
biggest issue is getting any manual 4WD trans to bolt to the KL block. Once that's done, it's all just money and fabrication...
I think you can take the bell-housing side of the transmission case and swap between KL and BP patterns with the FWD G-box, but I think there's enough different in the 4WD box and the 2WD box that it won't work going from FWD to 4WD.
nothing a LARGE bandsaw, a welder set up for AL, and a few hours' time can't take care of, though...
How much shorter (if any) is the KL than the BP? If it is a bit shorter, it might even make it easier to fit an E153 in there, maybe no need for the frame rail to be sliced/diced...
It would be fun for sure. I was kinda thinking of it the other day, but decided to stop before I got myself into trouble.
Hell, why not make the 1uz-fe mated to the E153 AWD box? 4.0L of V8 aweseomeness!!
--sarge
