What years are interchangable for clutches? Will a SOHC clutch work in the GTX or is there a specific one that needs to work?
What clutch will fit a GTX?
1988 323 GTX - "Miss Becky" - VJ-11, Autometer Sport Comp boost gauge, Sachs Clutch, K&N Air Filter. Freshly rebuilt engine with Clevite Bearings, Fel-Pro Gaskets and NGKs, 2.5" Exhaust from turbo back with a Turbo muffler.
1970 Chevelle SS - "Krista"/"ALMYDOE" - restored from the ground up, 350/350, lowered 2" frnt 1" rear, flowmaster 40 series, Holley Street Avenger, GMPP intake, American Racing Torqlites. (Ported and Polished ZZ4 Aluminum Heads coming soon)Tags: None
Upon some further searching it turns out the SOHC cluthc is more then an inch smaller in Dia.1988 323 GTX - "Miss Becky" - VJ-11, Autometer Sport Comp boost gauge, Sachs Clutch, K&N Air Filter. Freshly rebuilt engine with Clevite Bearings, Fel-Pro Gaskets and NGKs, 2.5" Exhaust from turbo back with a Turbo muffler.
Im pretty sure the Gseries clutch will work.
At one point I had both and the friction disc was the same measurement and thickness between the twoI live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important.
._________________________
From www.mazdaspeedmotorsports.com :
DISC, CLUTCH (ACT)
MX-3, 626, MX-6, MIATA, RX-7, PROTEGE 2.0
1986-03 $153.28
225mm ACT Street Disc. Designed for smooth engagement, quiet operation and improved durability using only the best organic, spring center designs. MZSD056S Fits 1.8 Miata, All 1983-97 626/MX-6 w/o turbo, 323 GT/GTX, & 83-88 RX-7
Notes: 3000203 SAME-5413-AC
For Centerforce DF:
DF CLUTCH ASSY
323 GTX 1.6 DOHC T 1988-89 $325.72
Centerforce Dual-Friction clutch is specifically designed for autocross and racing applications. A race-proven centrifugal weight system on the pressure plate generates up to a 90 increase in holding capacity over a stock clutch, with minimal increase in pedal pressure. Disc features unique carbon-fiber facings which are lighter, more hear and oil resistant, and less abrasive than metallic facings. Includes Pressure Plate and Disc. Use with Mazda Factory throwout bearing.
Notes: DF543007 88-89 323 GTX
