I'm new to mazdas and I'm not to sure about what I can do to make this little car handle better. I was wondering if it is at all possible to swap the drive train from the 323 gt-x into the lx to make it 4wd. I looked on all the bf threads and I couldn't find anything on this topic
323 lx sedan 4wd
Wrong floorpan, wrong trans tunnel, wrong rear subframe, wrong gas tank. So no you can't just swap the drivetrain in. But it can still be made to handle better with the usual suspension upgrades.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
It's not that it can't be done, it would just take a parts GTX and a substantial bit of fabrication. If you're truly confident you have strong fabrication skills, I say go for it. Otherwise find a GTX to drive. A front wheel drive car can probably handle better than you expect with the right suspension setup and a limited slip differential.
I have both a GT and a GTX, there is a lot that is different chassis wise.Last edited by DuRWooD; 07-01-2011, 01:12 PM.sigpic
1992 Familia GT-X
1988 323 GTX
2011 F150 Lariat Ecoboost
2014 Civic Touring
there are a few that have done awd swaps into fwd cars, there was a guy on a nother forum that swaped the bf awd stuff onto a bg mercury tracer, a guy on here has a awd mx-3 with iirc bg awd stuff and a nother member has a 91-94 capri with iirc bf awd stuff....
do alot of research, im guess if you found a bf awd parts car it could be done relatively easy, but will be pretty involved,measure,measure,measure,, the guy that did the awd capri would be a great place to start for info...Last edited by ryan1; 07-01-2011, 11:11 PM.5 boosted bp cars,why...
Have you thought about a twin engine setup? I don't know if anyone has done that in a BF or BG.1990 Protege 4WD
1 3 5
2 4 R
bg tracer awd swap, iirc he used a mix of bf and bg parts.
After spending three years on the Miata and taking third last year, it's time to head in a different direction. Something new and quite different must be built – something other than a car with a turbo slapped on and a paint job. Enter my '91 Mercury Tracer LTS. That's right, a four door...
a ? for the 4 door owners, low much longer (wheel base) are the 4 door 323's than the hatchback ones?Last edited by ryan1; 07-05-2011, 12:04 PM.5 boosted bp cars,why...
Originally posted by ryan1 View Posta ? for the 4 door owners, low much longer (wheel base) are the 4 door 323's than the hatchback ones?
The BG four door wheelbase is 98.4 inches.1990 Protege 4WD
1 3 5
2 4 R
Originally posted by DuRWooD View PostI went and measured both my BFs for you, the sedan and the hatchback measured the same, although I was by myself using a tape measure.Last edited by ryan1; 07-05-2011, 10:11 PM.5 boosted bp cars,why...
