I've search and read different threads and I can't find one where someone has swapped the entire bg gtx drivetrain into a bf gtx. Is this feasible? I've read you can use awd bg suspension with mixing of some bf parts. An I've seen the bg gtx motor and trans swapped in. What I haven't read is if the rear diff. Can be swapped in an if the whole rear sub frame is used.
Essentially can you buy a front clip that includes the rear suspension and build a bg gtx out of a bf?
