Hey, I recently had a transfer case go out in my 1988 gtx, and was having trouble sourcing a replacement, as well as I wasn't sure if I wanted to risk blowing another awd one again, since the car is really just my daily so I just need it to work.
I picked up a G series transmission out of a 91 Capri, and I was wondering what exactly I needed to make it work. Obviously the axles will need to be replaced, and it appears I need the shift linkage assembly, since the gtx has cables instead of linkages. I read online that I would need to drill the floor some to make them fit. That's fine, but what about the cable clutch? Are there any mounting provisions on the GTX clutch pedal for a cable clutch? Do I need a 323 gt clutch pedal assembly?
I've been scouring the net trying to find someone that has done such a swap, but without luck. Can anyone tell me what exactly is going to have to happen to get this transmission inside this car and working?
