I had some idle issue(low idle at cold). I unbolt the Idle Air Control valve and the valve is stuck close. I have found my issue ...
I dismantled this part clean as much as possible . Bolt on the engine : My idle at cold at 1200 rpm hot at 850 rpm : Perfect!!!
today I start my engine : same idle issue!!!
Valve is still in close position!!!
Any idea to fix this ? the mazda IAC is very very expensive (800$) I heard about BMW IAC valve is a bolt on replacement. Anybody with more info on this?
