Fmic
    Fmic
    What options do I have for an fmic? I can get one from a 1jz supra with piping for $40. I have the probe smic but it still heatsoaks pretty bad.
    I know I'll have to cut the bumper out some but I don't have a problem with that. I just wana help with the heat as it is now after a hard run the cold pipe is so hot I can't even touch it
    Just looking to see what other people have done
    I've seen many different setups from:
    Probe/MX-6
    Saab
    Supra
    Starion (modded inlet/outlet)
    Bell intercoolers
    And air/liquid intercooler setups.
    The main limiting factors are deleting a/c and using a different bumper. If I were to do it again, I would get a bumper from eBay.de
      I don't know how people get a intercooler longer than 23-24"total length with out cutting out one of the vertical rad supports.Even if you remove em I don't think that would help much either.Even the gtae bumper is a tight fit,hard to go thicker than 2.25-2.5".I still a have puny intercooler,found a used cusco that was aprox.25" wide and 10-11"(don't really remember that) tall and2.5"thick.And I think that would need some welding to get in.
        why not go water to air?
        1990 Protege 4WD 5 Speed
          Or you can get stupid and put custom end tanks on a saab 9000 IC...Corskport did this one. I bet they regretted it.Click image for larger version
            I have no ac so that's not an issue. I'm not doing a water to air because I don't plan on keeping the car forever. I can weld anything so mounting isn't a huge issue
