Trying to figure out how cheaply I can do a bp swap for. Motor just needs to last till winter. Here is where the fun begins, I have a fwd g series trans from a Capri xr2 now, most of them are interchangeable so I would like to keep it for now. I can get a bp out of an escort gt for $200. I was planing on using my gtx rods in the bp to lower compression a bit.
I know I can run the bp off my current ecu, I'm wondering what all I will need. I know there's the obvious fluids timing belt water pump clutch etc. but to actually get the motor in I'm hoping for just the passenger side motor mount only.if I have to custom make one to be able to use my current axles and everything I will. I don't have power steering or ac. My motor is nearing its end and I doubt it will make it till winter.
I have more turbo than what the bp will be able to handle so I'm sure ill have to come up with a tuning solutiOn once I want to push it a bit so towards winter expect some decent numbers from a bp, or of its too expensive a b6t
