So I'm in the process of Megasquirting my B6t engine.
I can't figure out what all the wires in the injector loom do...
The four yellow wires to the right splice into two wires, and run back to the ecu... I assume these are the injector signals.
The four blue wires taped in a bunch run to the resistor pack (positive feed for the injectors)
The green wire runs in the direction of the ECU, where it finds a relay, which I had spliced a wire into, and was running the fuel pump from this.. I assume this is a wire that only has +12volts on it when the engine is running.. as this is what I was using it for? Is this what its meant to be?!
The two blue wire/yellow trace wires splice together, then go to the TPS... on their way back to the ecu, the wire is then spliced again, and runs to the air flow meter... This appears to be one end of the temperature sensor...
blue/red trace splice together as well, and run straight back to the ecu.. I believe the other end of the temp sensor...
And finally, the black wire, splices into a hand full of other black wires (I assume its a ground... it connects to the shield on a few shielded wires too)
BUT!
In the loom on the engine itself, there's a two conductor loom that runs down somewhere behind the engine... I thought this was the IAC valve... but what wires go to it?
On another note, why would there be a ground, and +12volt feed to the injector loom anyway? I measure 40ohms across these two wires (black and green in the picture)
Across the two wires that I concluded where the temp sensor, I measured 2.7k (which is in spec for the thermo sensor, at the current ambient temperature)
Any help would be fantastic!
Thanks!
BUT!
Thanks!
