The plate behind cam gears with 12 o'clock marks.. is that piece mandatory?
plate behind gears
I think it might have a role to play in keeping the cam seals where they need to stay but can't remember for sure. i think it also locates the timing belt cover. Running without that stuff prolly isn't the end of the world, til something falls in there of course...'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
Originally posted by jay View PostI think it might have a role to play in keeping the cam seals where they need to stay but can't remember for sure. i think it also locates the timing belt cover. Running without that stuff prolly isn't the end of the world, til something falls in there of course...
Been long enough since I've dealt with a 1.6 that I couldn't recall.but yeah I spect it's there primarily to provide timing marks. On the street you're orolly fine running coverless if you're looking to show off fancy camgears or something... but if I tried that with the rallykar I might as well just park it, duhhh'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
it is not mandatory. & quite often becomes a problem dropping the 10mm bolts out into the timing belt.
I highly encourage you to remove the plate. it is there however for setting the timing. so you will need to cut it enough to make a slip fit behind the cam gears so you can put in 2 outer 10mm bolts & set the timing. then pull it back out.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
