So I'm fitting a B6t engine to my KE Ford Laser (same as the BF 323) along with a Megasquirt ecu to control it, running a wasted spark setup, and Miata/MX5 cam angle sensor bolted in place of the stock distributor.
Now, the B6t head has two mounting bolts for the dissy, meaning, the CAS can be bolted in two different ways.
Can I fit the CAS either way, or will this make it impossible to get the timing even close to being correct?
Thanks!
Thanks!
