Hey there everyone. Despite all of my attempts to keep my Festiva B6T alive, it seems futile to continue plugging away at this motor without a rebuild/replacement. The oil consumption and intermittent blue smoke is just too arduous to overcome, and I'm convinced it's a rings issue given everything else has been tended to in the past six months from fresh oil and PCV to new valve stem seals, the head-gasket, and turbo.
So it's looking like I'll probably build up a second engine or at least prepare a second short-block for the engine swap procedure. I happen to have a Miata short-block sitting at a friend's garage. What I don't know is whether there are any compatibility issues between the FWD and RWD motors... specifically the flow of coolant and the like.
Does anybody have any experience with swapping in a Miata short-block into a FWD chassis with a B6T top-end? I'll obviously use the B6T oil pan so I can drain the oil from the turbo. Anything else worth thinking about? I'm aware of the fact that the B6T rods are superior as well.
