so i went to the junkyard and i found some 96 saab 2.0 turbo injectors red tops.. with little modification i got them to fit perfect they are 350cc at 45psi. so i put them in and bumped the boost to 13 psi (stock ecu, 2 1/2 exhaust and cone filter) i figured thats about as much as i wanna run since stock ecu runs out of fuel after about 11 or 12 psi...
im thinking when i get the el prototype ecu and my new vj11/16t ebay hybrid turbo and FMIC installed ill try for 20 psi.. anyone have a similar setup? i may need an adjustable FPR but we'll see. ill be installing my wideband when i put the boost that high to make sure all is good. but if anyone has a similar setup and help or recommendations would be great thanks
Lando
Lando
