3 fuel pumps have stop working properly in 3 months. 1st Walbro 255lph, 2nd used stock Protege most recently WRX Sti this lasted 3 weeks. What could be the cause of this?
Walbro 255lph stop pumping but can hear the pump making noise as if it is pumping.
Used stock Protege pumping very low, like when you turn on a garden hose slightly.
WRX Sti same as Protege pump
I have never run out of gas with any of these fuel pumps & they all have the strainer installed on them.
I am wonder if i am having a low voltage issue.
I need some info on how much voltage should the gas pump be geting?
I am getting 7.2v - 8v during start up I am uncertain if this ok.
How much volt so i be getting when the engine throttling?
