Can I haz popcorn??
Am I cheating on my GT?
Did a little more research, sticking with COBB, they can offer 16.3% and 16.9% increases in HP and torque bringing it up to ~305HP and ~327ft-lbs (with exhaust done). Add on intake and a FMIC and maybe you'll hit the figures you're talking about, but not at the wheels.
2007 Speed3 vs 2007 WRX vs 2001 WRX (base stats from edmunds.com), all with a tune (cobbtuning.com) & exhaust
305hp ... 277hp ... 310hp
327lbs/ft ... 328lbs/ft ... 294lbs/ft
3153lbs ... 3192lbs ... 3175lbs
FWD (limited boost in 1st & second gear to prevent wheel spin) .. AWD .. AWD
Pretty even matchup still between the 2007s, and could potentialy walk the 2010 WRX... not what I expected! New opinion formed based on theoretical data I wonder when the tune came out, rather recently? I don't remember it being an option a year ago.
Edit: I Couldn't find the release date, but on Dec 2, 2009, they were still working on the product for release. I also found out while discovering that info, that their intake system gives a 31whp and 34lbs/ft of torque over stock, pretty damn impressive. http://blogs.cobbtuning.com/2009/12/...add-big-power/Last edited by Crazy Drummer69; 03-15-2010, 01:57 PM.
1993 Mazda Familia GTR - work log
Originally posted by Crazy Drummer69 View PostDid a little more research, sticking with COBB, they can offer 16.3% and 16.9% increases in HP and torque bringing it up to ~305HP and ~327ft-lbs (with exhaust done). Add on intake and a FMIC and maybe you'll hit the figures you're talking about, but not at the wheels.
07 Speed3 vs 07 WRX (base stats from edmunds.com), both with a tune (cobbtuning.com) & exhaust
305hp ... 277hp
327ft-lbs ... 328ft-lbs
3153lbs ... 3192lbs
Pretty even matchup still... not what I expected, new opinion formed based on theoretical data I wonder when the tune came out, rather recently?
Well, COBB also offers the AccessTuner Race which allows the user to change everything from throttle mapping to boost to variable valve timing to AFR etc.
The off the shelf maps you are reading about are mild at best.
The limitation in hp you see with the MS3 is in large part due to the stock calibration closing the throttle at 5500RPM. As you know HP rises above torque at 5252RPM and this results in little time to build HP.
The stock turbo can be spiked above 20psi but it likes to be around that point. Most people that throw bolt-ons on the car have mixed results because they are fighting the restrictive ECU tune and along with that a weak cam driven fuel pump and boost cuts.
Once you bolt the engine and get a decent tune at around 20psi, these are the whp numbers you can expect from the MS3 with the stock turbo. Note that this was a tweaked off the shelf map. He had another 20 or so whp after a pro-tune. As you can see, the car made well into the 300whp and over 350 ft lbs of torque. Moral of the story, don't base your opinion just on advertised numbers. You'd have to do quite a bit to a WRX to walk an MS3 on the hwy.Last edited by Lex; 03-15-2010, 01:52 PM.
Mazda did a good job on the tranny this time as well. The 3 shaft MS3/MS6 tranny is a bear and people aren't breaking this thing with over 400 ft lbs to the wheels. Stock clutch holds well as well. They finally learned I guess.
The motors are more fragile however and need to be well tuned because they don't like low RPM boost and torque spikes which the stock turbo is known for. People who just throw flow mods at the car without a tune end up with 22+psi boost spikes down low and that spells trouble.
Alas people always want more power (and when they have it they realize FWD and 400 ft lbs is not so great) so the "progression" car is generally an Evo.
"Progression" car = '90 Protege 4WD!! (with ST-205 drivetrain, lol!)!!
Seriously, though, the EVO 8/9 are the ONLY cars I've ever driven that have made me seriously consider a purchase.
Possibly a Subaru 2.5RS, depending on what it's being used for. I absolutely LOVE the gear ratios and powerband
Of course, if they ever make the Speed3 an AWD vehicle, I might just forsake my BG stable...
But I digress. Like you say, everyone want's Big Numbers. I was recently told to not focus so much on the numbers, and try to focus on what the goal is.
gigantic numbers , if they're in a place where the car can't use them, are just a waste of money!
--sarge
Originally posted by SgtRauksauff View Postif they ever make the Speed3 an AWD vehicle, I might just forsake my BG stable...
DG MOTORSPORTS - AWR MAZDASPEED3 At first glance, the DG Motorsports AWD MAZDASPEED3 may look like the stereotypical SEMA show sport compact, but the truth lies hidden beneath. MAZDASPEED, DG Motorsports and AWR teamed up to build much more than the average tuner car. David Green, owner and chief designer of DG Motorsports, felt that
Now that the dust has settled on our MAZDASPEED3 AWD Project, we got around to sorting out the specs. With all the modifications we did to the stock MAZDASPEED3 , we only gained approx 60 lbs. Amazing and still 400 lbs lighter than a MAZDASPEED6. MazdaSpeed 3 MazdaSpeed 3 AWD MazdaSpeed 6 Lowered yes yes
Originally posted by deadly_sleeper View PostSince it is an 07, they had some problems with some of them at the factory and the rear motor mount was not tightened all the way, and the bolt will work itself out, you might want to check the service records on it or crawl under the car yourself. If loose, pull the bolt out (the other motor mounts will hold the engine in place, no need for jacks) and put some lock tight on it and tighten it to spec. Or just pull out the weak RMM now and replace it will a stiffer one and then not have to worry about it. But either way, I'd still check it for piece of mind.
Originally posted by BFMRGTX View PostNice score on the MS3, Kyle. If my brother keeps throwing the keys to his MS3 at me saying: "buy this from me", I just might take him up on it.
Terry, I cant tell you how much I love this car. But, thats not saying much comming from someone whos only ever really owned a stripped down BF GT and a 66' Impala. If you want an awesome car thats worth its weight in gold (Well, it is to me anyways) the go for it. Oh, tell him ppl are picking them up for as little as $10k and see what he says for a price.Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
Originally posted by 808 View PostBye bye 323 GT.. Wanna just sell it to me now and get it over with?Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
My only caveat: I honestly think that Mazda's body styling for this generation is not so good - with the exception of the MS6. I really dig everything else about it. After a few autocross sessions, I was sold.
But time will tell if I end up getting it. The Jetta gets some damn good mileage but it's boring. The MS3 would make a fun, yet expensive commuter car.
