I posted on another forum, sorry if you have seen this before.
I bought my bone stock 323 GT today for $580. There are quite a few minor problems
1. The passengers lock cylinder was moved to the drivers door after the drivers went out
2. The Gas gauge does not work
3. The trunk lock is missing a spring
4. The RH/D side shock has a broken boot
5. The cd player was installed poorly/ Front speakers dont work
6. The front has a clunk like a bad ball joint or bad motor mount
7. Surface rust
8. Drivers window sounds like it skips off its gears if you roll it up past all the way.
9. The speedo wines in the winter... possible speedo cable??
10. One of the ebake cables is broken
11. No cat back (fell off)
12. needs an alignment
13. I am forgetting something
Where can I get good fair priced STOCK parts?
I will take car of the serious ones asap. She runs drives and boosts great . She has 206k miles and a lot left. I would like to add a few minor mods to get her to smoke some ricers but I am not looking to break the bank or create a masterpiece.
I was thinking about
1. Bigger FMIC
2. putting on a thicker exhaust 2.5 inch.
3. Maybe a new turbo/ rebuild current one?
4. I want the BOV sound but I know I need a recirculating type Valve. I know a few brands that claim to do both.
5. stiffin the chassis a bit, I want to stay in the seat for sharp corners.
6.?? you tell me.. where should I start for mods, what should I do, where can I get good fair priced parts?
Thanks
-Brian
7. Surface rust
1. Bigger FMIC
Thanks
-Brian
