After searching and reading I am guessing that the cable or drive gear are hosed. Any suggestions for the job? I guess I'll pull the gear end first and spin the cable if the gear looks good to check the speedo.
I hate working under the dashboard of a car. Is there an easy way to get to the cable on the back of the cluster? Is the cable clipped to the cluster?
Any junkyard donors for used parts? If I need new I ordered from Arlington Mazda and Jim Ellis previously. Any better suggestions?
Can I replace the inner cable if that is the problem?
Car is still running good, it is a daily driver now. Idle not perfect on a warm start. Gearing pretty low, could use sixth gear.
