hows the axle situation coming along?
My Stroker 2.2 in the build(Lots of Pictures)
soon my pretties!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
looks like its coming along pretty good.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
uniformly clean! i like the original color scheme.
I also need to find myself one of those valve cover badges---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
thats putting alot of heat right at the rubber. is there no option for normal exhaust?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
