Galant Brake Upgrade
    Originally posted by trailrider098 View Post
    i did the galant rotor/ EGT calipers upgrade on my GTX and it worked out great, i also changed out the MC to a 92'' 929 one and the brake booser to a 96'' 626 one. the whole setup feels and works great. if anyone has ??'s about how to do it PM me and i could help
    The 929 MC is the only thing I haven't done yet. I'm chicken. I don't think I can bend the metal hose without breakin' it. Maybe someday you can help with that? I guess I should start looking for a 929 MC first..... LOL
      Go git yerself a brakeline bending tool from NAPA and be done with it!
        dont be scared of it, i did it by hand cause its so simple. there are two brake lines that go into the MC, one screws right in without bending. the other looks like it fits but the threads are a different size. so what u gotta do is get the 90* fitting and banjo bolt that screw into the MC (all stock parts on the 929)and put them on facing down. Now all u gotta do is take the brake line with two hands and twist it so instead on going into the MC horizontaly it goes into the banjo bolt verticly. You really only twist it 90 degrees, not even much bending.
        -93' Mazda Miata, half caged
        -09' Mercedes C63 AMG
          There are fairly cheap tubing bender available from your "cheap tool" stores. It should work fine if you are just needing it for the 1 job.
            4 piston calipers
            I have yet to complete the project, but late 80's RX-7's had aluminum 4 piston calipers. I was mocking it up, and going to keep my galant rotors or upgrade to the 5 lug RX-7 hubs and use 16" wheels. It is possible. The early Rally 323 GTX's did it on all 4 corners.
              are there posible to use rx7 gen2 front brakes? the one with 114,3?
                Anything is possible. I never personally seen gen 2 brakes from an rx7. calipers are slightly bigger, but the same, I think. I only looked at a picture of them. sure, its possible. its just a matter of knowledge and/or money.
                  Guess I'm going to have to start looking for RX-7 2nd gen brake now, too!
                    Yeah, me to
                      which parts? calipers work... i'm not sure what kind of modification or bracket it takes though...
                      1988 White GTX - #1 parts
                      1988 White GTX - #5 Rally car
                        The Myth is that you can modify front spindles of the BF 323 to accept the rear hub part of 90-ish RX7. Vice versa if you want rear 4 pistons. Boom, now you have 5 lug hubs, then you make a bracket or drill factory spindles out to accept 4 piston calipers. I think you can still use Gallant rotors if you dont go 5 lug. My reccomendation is to stick to the earlier parts. cheaper and easier to find. Rebuilt 4 piston calipersare about $45 each at advance auto.
                          really helpful info. i'm going to do the Galant brake upgrade and give it a shot
                          quick question, what year of Galant rotor should i be looking for?
                          also, will the Escort GT caliper directly bolt onto the knickle without any bridge/modification? as well as the front break lines?
                          thanks!
                            thanks!
                            Sorry to revive a dead thread but I'm wondering the same thing about the rotors and calipers ... also longer studs.
                            So this will push the wheels out 6mm?
                              To update! The yahoo group has the information on the database.
                              Now is it at all possible to use the GTX calipers? I'll upgrade the calipers in the future, I just have more pressing things to spend my money on and I'm replacing the front bearings anyways.
