was reading on an open class rally 88 gtx that was running 93 accord wagon front rotors (10.21 dia x .91 thick) and rx7 calipers up front and stock gtx fronts on rear.
?? Simple Brake upgrade: 4 lug 86 - 89 BF w/r Drum ??
Originally posted by pikespeakgtx View PostWhat about just upgrading to the 22V, escort calipers and using them on the stock rotors??
Anyone else tried this? The rotors are only 2mm wider so this should work.
Price out a set of new front calipers for a 95 escort. Trade in your old ones for the core. They won't notice. They'll have 22V inscribed on them. Yours should say 18V. The caliper piston is larger. You'll have more pedal travel but the stopping power will increase some since the caliper piston is larger and transfer more force (pounds per sq in) to the pads.
You can always upgrade to the galant 266mm rotors later if you want. It's not that hardcore of an upgrade... it's the next logical step. So next time you replace your rotors you don't have to remove the hubs. I'd do it now if I were you.
Originally posted by kaputt 323 View PostHow would I go about converting those crappy drums to discs on my base SE or LX?"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
Originally posted by trailrider098 View Postfind a 323 GT and take all the brakes and knuckles and bolt them on
Originally posted by Threetwenty3 View PostWhats the smallest wheel size you can use for the Gallant upgrade? Ive got the stock 14s on my GT. Will those work?
Also whats the difference between calipers stamped 22v 13 and 22v 14? I just realized I picked up 22v 13's."See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
