Aha, thanks for the comments. That's very helpful info.
Did you add new bars or something? As for street alignment, I typically run something like -1.5deg/0deg camber (& 0deg toe) front/rear. It's fairly balanced on dry tarmac when run along with Bilstein inserts (VW Rabbit Sport/HD) and Pedders lowering springs. I've also got 205/50/15 tires mounted on 15x7" rims (Rota Grid w50mm ET + 6mm thick outboard rotors). Tire pressure is maintained at 44psi/40psi front/rear.
I'm curious to know what others have preferred.
Originally posted by Talkurt
View Post
