precisely. i gotta think about money. im married and havent found a new job yet.
order exhaust parts today.
well got everything installed today looks good althou correct the paint doesnt last long didnt even last the drive home from the shop but thats ok. i dont care how it looks. runs great and sounds great. no bee sound ect.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
well im happy with it but i cleaned my engine bay(never a good thing) and now ive got a wierd intermitent misfire hopefully its just something isnt dry yet. but i have no cel and no codes so nuthing i can do about it untill i get one of those its a shot in the dark.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
when i get a mic i will. prob water in the spark plugs holes but we will see. letting sit over night then try and figure it out in the morning. atleast my car sounds good but damn it looks like ass. prob wont touch the body untill winter or when i get my other scort streetable whichever happens first.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
I bet you got water in your distributor cap as well. should check both. When I use to have my gt I had a custom hood that I was building, almost like the invader. I used to get water in my distributor cap and plug wells all the time. It would run like crap. There was a couple of rainny days where I had to pull over and dry everything out. Sucked big time.97 protege dx few mods
94 escort lx heavily modded
yep im gonna pop off the cap and spray it down with wd and then maybe do the same with the wires we'll see.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
i wipe off the wd its just to get rid of the water... either way wasnt needed went out this morning turned the key and it started right up.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
well running great now. was able to dust a riced out civic last night with ease. i didnt know we were raceing untill we hit 40 but i guess we were. floored at that point pulled 3 legths on him and let off.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
yea, the pacesetter is an ALRIGHT unit, i have the 4-2-1 on my EGT at the moment, i just did some prepping before it went in, i made sure both ports were the same szie and smooth (engine and header) then i chopped the header off right where it started to round off from the 2-1 connection, and made it 2.5" to the muffler, but a hollowed out cat, a nice resonator, and a used magnaflow muffler (it was on my truck before) and i was off!
the car had great responce once it was over 3,500rpm...before that, haha, BOGGGGGG!. but that exhaust mixed in with a 3" CAI, P&P intake mani, bored out TB, timing advanced, coil pack, taylor 8mm wires made for a fun drive! the tires were just HATING 2nd gear
needles to say i did notice a HUGE difference in power with the exhaust work, i'd say anywhere from 7-12whp. it went from 'erp' in 2nd to 'CHIRRRP' and the car letting loose!
i think im the only FWD car in my area that can make their car kick out sideways when shifting into 2nd
JACK-Jack
mine is the 4-1 so not the same. totally stock cept for a 2 degree advance on the timeing. shift to second is a nice scratch and 3rd does a erp if i shift right at 6750.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
