i ordered the pacesetter painted header today, magnaflow(carsound) 2.25 highflow cat, 4 inch round 2.25 muffler to use as my mid muffler and a 4x9 inch oval 2.25 inlet offset outlet magnaflow muffler for the rear muffler.
order exhaust parts today.
suspension: s/r struts intrack springs and intrax sway bars 15x6.5 rims kumho mx tires 205 50 r 15Tags: None
EGT I went with the pacesetter to keep things cheap for now. I am still debating on whether to do an na or boosted buildup prob will be boosted thus this exhaust will just be temp.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
ive heard genie is very good altho to be honest i am planning to fab on up myself if i do a n'a buildupmods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
hey as long as i dont lose power over the stock mani im good. and that happening is such a rare chance i doubt it will. happened with my 89 scort but that was because of conditions unforseen ie ports being to big. wierd when that happens. but thats what happens when you try to shoot for 200 whp out of a 1.9 namods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Is it just a plain aluminized Magnaflow muffler on the back? If so, get the Pacesetter resonated tip. They make a single 4" and single 3" one with 2.25" inlet. I got the 4" over the 3" tip just because there were a bunch on eBay at the time for $20 shipped. I probably would have went with the 3" if I had to pay full price. And BTW, the yellow stripe comes off if you don't like that part.
Originally posted by Chadyeah pacesetter sucks i wish i would have went with the genie., but i was poor, and hell still am , oh wait.., always will be
I was considering selling my pacesetter 4-2-1, which I believe is no longer available, and getting a genie for when I do the rest of my exhaust.
The genie looks a lot nicer and looks like it is a much better quality constructed piece, but the pacesetter 4-2-1 is actually a better design, so I stuck with it. Sure it has its drawbacks: the paint smokes off and the welds aren't the best and have to be repaired over time, but for what you pay for it, its definitely the best bang for the buck.
The new 4-1 pacesetter on the other hand, I dunno aboot that one.....
one magnaflow does not make aluminized the ones that look like they are are unpolished ss. also i got a tip from magnaflow duel 3 inch double wallmods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
jho hmmm.... see ive seen both listed but when i talked to the guy where i ordered it he said it looked like a 4-2-1 but he is prob an idiot ill let you know what it is when it gets here.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
does your 4" diameter round magnaflow muffler have a 2.25" core? I was looking into getting a 4" dia. for my dad's oldsmobile intrigue a few weeks ago, and I found that they had either a 2.5" core, or a 2" core, both with 2.25" inlet/outlet. I then opted to go with the 6" diameter, which has a full-on 2.25" core and inlet/outlet.
If your core is 2.25", could you list the part number, as that is the preferable size that I'll be getting when I redo my EGT exhaust in a few weeks.
Hmm.. Just looking at Magnaflow's page, the 14" body (20" overall, which is what I was using) is either the 2.5" (10415) or 2" (10445) core, but the 22" body (28" overall, 10435) and the 18" body (24" overall, 10425) don't mention a discrepancy in the core size from the outlet size. hmm...
--sarge
2.5 inch core. i used it before on a couple cars. not a problem that at all works fine no loss of pressure sound seems a lil deeper. but be warned if useing it was your only muffler its almost as loud as str8t pipes.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
btw i ordered all this from superexhaust.com and magnaflowonline.com(or whatever there name is now) i paid 394 and some change for the 2 mufflers cat header and tipmods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
