anyone know if it will fit or if id need a laser front bumber too?
ford laser lip on EGT?
suspension: s/r struts intrack springs and intrax sway bars 15x6.5 rims kumho mx tires 205 50 r 15Tags: None
well that sucks. anyone know of a lip that will fit the gt one?mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by neuspeedescortit will fit the LX-e and LTS from what i know.
NEUMAN
The lts is...a different story because the bumper is slightly different. But the lts comes with a lip OEM, so maybe you can just swap.
adam had the laser lip on tammy's hatch at one point.Seth
2010 Mazda3 i Touring
so im thinking i would need to get a lx front bumber to use the lip. hmmmm....mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
all truth my gt bumber is a lil scratched up i need to fix it. the body of my gt needs so much work its not even funny. gonna take me a full week to get the dents out. (if im lucky) ill prob stick with the gt bumpers or do a crx/civic custom kit. once i get to the body (prob august) ill make my decision but i live in OKmods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
why dont you just grab a honda accord front lip and cut 2" out of the middle and strap that bitch on? it'd look sick, i have a EGT bumper with a civic lip, and it was about 3" to short on either side, but i took care of that
JACK-Jack
ill think about it.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
