I hate to keep posting but I cannot find anything on this anywhere.
I am losing pedal pressure when holding the clutch in.
Here's the setup - - Just got done doing a tranny install with flywheel, clutch, etc...... I had replaced both the master and slave cylinders about 6mo. ago due to the same problem, seemed to go away but it came back again. As far as leaks there are none, the line between the reserve and the master is new steel, and the one from the master to the slave is about a year old, mixed line (some rubber some steel).
I'm not sure if I bled the line correctly, I used same as bleeding the brakes, 3 pump hold the last open bleeder, repeat........no air is in the line (as far as I can tell) used a half a bottle of brake fliud doing it.
What am I missing?
What am I missing?
