You can make the alternator work don't get me wrong ... it's simple and so is the PS pump, just change the high pressure pump that attaches to the pump.
91-96 Escort GT vs. 90-94 Protege LX - important similarities and differences
My Protege GTs BP seems to have a sensor/plug at the front of the block...the wire that hooks up to it looks like a typical household chord. It's for coolant since i tried to remove it...coolant leaked out. The plug is 3 prong.
Do i have to swap this **** over to my EGT BP that im dropping in today???
PS. i couldnt find out where the wire/chord went to.
JACK.-Jack
sounds like a block heater to me........ if you dont want it or need it i'll take it!!!Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Turns out the EGT motor has a block heater too, but its at the back of the block near the oil filterlooks like im pluggin this bitch in come winter
hah
JACK.-Jack
Originally posted by therieldeal View PostIf you have a 91-93 escort, only one of your rear lateral links is adjustable.sigpic
92 240SX: KA/T25, nerd mobile
it may have been replaced at some point, as all replacement links are the adjustable type. ive seen many many escorts in the junkyard and ive owned and/or worked on a few (91x2, 92, 93, 94x2, 95) and only 94+ ever had an adjustable drivers side rear link. perhaps it changed mid-year in 93?
btw where is head wound city, CT?Last edited by therieldeal; 07-03-2007, 01:07 PM.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Not sure- for some reason I've only seen LXs with the one adjustable, the GTs i've owned and worked on had duals. Pretty sure the ones on my cars are originals, but at this point, who knows.
HWC is a band. Just felt like it would make a great location for forums.sigpic
hmm, weird.
91x2, 93, and 95 out of that list ive owned/worked on were GT's. the others were LX's.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
cheap ford junk
Whoops did i type that?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
arent the axles and wheel studs the same as well?"Beer is proof that God loves us and wants us to be happy"
-Benjamin Franklin
i wish my grass was emo, then it would cut itself
-dedicated to sling blade, aka, meltdownsky
this is a horrible trick and should be deleted immedately - wheresthericego
yes---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
yes, i think i mentioned that somewhere in there.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
