Originally posted by chrmar
View Post
91-96 Escort GT vs. 90-94 Protege LX - important similarities and differences
the brackets for the radiator are in different locationsEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
yep, can't swap rads w/o a bit of custom work-Jack
these statements are correct, if you have access to a welder it should be about a half hour affair. all you really need to do is unbolt the stock brackets for the rad, after you get someone to hold the rad in place when another person welds the brackets into place,and you are done. it isn't that difficult just requires access to a welder. i run an egt rad on my pro. works fine
No. The lx is a totally different car. Chassis is about the only thing that doesn't change1993 Protege LX-Midnight's shadow SOLD
suspension will interchange, brakes are the same as the protege DX/323
obviously the engine bay is 100% differentEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
neat?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
94 lx what? protege? if so yes it will fit.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
