Here's the circuit opening relay and pump section
As you can see the relay can be opened (pump can be turned on) in 1 of 2 ways. The first is when the starter is engaged and the second is when the VAF is opened. The starter wire that opens it is the violet wire. That should only be opening the relay while cranking on a stock car.
The light green wire is grounded when the airflow meter starts opening. When the VAF is completely closed, the pump is switched off for safety reasons. So grounding this light green wire will keep the pump on permanently as long as your ignition is ON. You can ground the light green by jumping it and GND and F/P in the diagnostics box in the engine bay.
The white/red is the 12 V wire that should be 12 V when ignition is on. The B/P wire going to the pump is what powers it, and it should be 12V when the car is running (VAF opened or cranking). The black wire from the pump down should be a solid ground.
So in other words, all you need to power the pump is to have the W/R wire have 12V, ground the light green wire, Ensure the B/P wire is 12V after you've grounded the LG wire, and ensure the black wire from the pump is a solid ground.
If you want to bypass the relay altogether, jump the B/P with W/R on the relay plug with the relay removed while the ignition is on.
Hope this helps!
Hope this helps!
